Most of us don't lurk around here in the middle of the night. This sub forum tends to run at a quite leisurely pace so patience is a key.![]()
First, you don't have a description of the sheath type, that will help us to tell you the best way to tighten it up.
Assuming its a pouch type sheath you can wet it under the tap with hot water, hot as you can stand it, till its pliable not floppy. If the leather is thin it wont take long to happen so be watchful.
Next take a smooth instrument, something like the rounded end of a sharpie pen and smooth the leather around the knife following the lines of the handle. Immediately remove the knife and wipe it down. You may have to re mold the sheath a few times as it AIR drys.
Depending on your climate it may take over night or longer for the sheath to dry. Do NOT use heat to dry your leather, don't use a microwave or hair dryer. If you must use artificial means to dry it take a small fan or fan forced heater on LOW and move the sheath occasionally for even drying.
