Aaron has an excellent thread discussing the strength of the bond between tangs and scales and this came up- I thought I'd pass this along in a thread of its own.
Looking at the table for bond strengths for West Systems epoxy, I noticed that it listed double the bond strength to steel if you "abrade through wet epoxy."
The way the West Systems techies explained it to me is this: The reason stainless steel is stainless is that it reacts with the air and forms a protective oxide layer. This happens very quickly- if you've done any aluminum welding, you know that this can be an issue even on a freshly ground, clean surface, and part of the reason for using AC high frequency is that the polarity has to be reversed many times a second to to clean the metal as you weld.
We think of aluminum and steel as very stable materials in terms of corrosion, but that's only because it corrodes REALLY FAST and then it's done, and the layer of oxide prevents further reaction.
The purpose of wet sanding is to bond to steel instead of the oxides on top of the steel.
So by this way of thinking, sandblasting helps, since it's more surface area, but you're still gluing to a thin oxide layer rather than the steel itself.
They recommended wire brushing, but I wasn't sure that it was suitable for a hardened, wear resistant alloy, so I chose to use a chunk of worn ceramic belt, since I see no evidence that it's shedding crud that would compromise the joint.
I'm trusting that one of the really knowledgeable people will correct this if I've made any assumptions that don't match how steels actually behave!
Hope this is helpful.
Andy
Andy
