Cliff Stamp
BANNED
- Oct 5, 1998
The axe head is hand forged most likely out of Swedish bandsaw steel (15n20)
and the edge tempered to 57-58 RC. The head of the axe is left in the
as-forged state except for the edge which has been shaped, sharpened and
polished. The head weighs 1 1/4" lbs, the total weight is 600 g. The
overall length is 12.25", the distance from the center of my grip to the
center of the head is 7.75" (for reference it is 8.75" on the Gransfors
Bruks Wildlife Hatchet). The head is centered on the handle, wedged in
place and secured with a metal locking ring. The handle is hickory,
vertical grain and has a slick finish that needs to be removed.
In regards to the quality of the forging, it is far below that seen on the
Gransfors Bruks Wildlife Hatchet. The Wetterling hatchet shows numerous fold
lines throughout the head and basically it is not well shaped. For example
the tip of the head should be flat, however it is not, there is actually a
dip present, more of a wave actually. As well most of the transitions are
not very smooth but are abrupt and angular. As well there has been shaping
done by a grinder along the underside of the head. The lugs are also
mishapen. Note most of these aspects are cosmetic.
The bit of the axe is a little thick. For comparison here are three
thickness measurements in inches taken along the bit of the Wetterling
hatchet as compared to the same place on the Gransfors Bruks Wildlife
hatchet; 0.440 (0.365), 0.295 (0.232), 0.205 (0.172). Note how the Gransfors
Bruks hatchet is significantly thinner. However what is interesting is that
the primary edge grind on the Wetterling axe is thinner than that of
the Bruks hatchet. Specifically the Bruks hatchet hits 0.25" in thickness at
1.35" back from the edge, on the Wetterling axe this thickness is hit
further back at 1.50", which is very good indeed.
However the edge has a significant problem in that there is a secondary
bevel about one mm or so wide. This bevel was measured in multiple places
and found to vary from about 21 to 30 degrees, the latter is far too obtuse
for wood work. The edge is also not evenly ground, the bevel is wider on
the heel of the bit than it is on the toe. A very light burr can also be
felt along the edge. However the hatchet is decently sharp. Getting
specific it will push cut light thread taking between 180 and 440 g.
Cutting 1/4" poly under a 1000 g load requires between 2.75 to 4.75 cm. The
heel of the bit is much sharper than the toe. For reference a sharp blade
will cut the thread at about 100 g and slice the poly under that load in
under one cm.
The handle design is very strong. The top of the handle in the grip region
should be an "S" shape. It should curve up to fill out the center of the
palm and then hollow out to give a smooth transition across the edge of the
hand. The bottom of the handle in this region hould have a very pronounced
hollow which is used both for security as well as for driving against for
very powerful snap cuts. This is exactly how the handle has been shaped. The
only negative aspect is that the end knob has extremely square edges which
should have all been rounded off.
I will sharpen this axe this evening, considering the decent quality of the
existing edge that will only take some work on fine sandpaper (5 Micron SiC)
and a quick polish on CrO loaded leather. I hope to get some use with it the
weekend. Assuming the steel quality is good, the secondary bevel will be
removed as that is only required if you are cutting really thick bone.
However even with this problem I still expect very good performance from the
hatchet and look forward to using it.
Ref :
http://www.garrettwade.com/images/26D1201.jpg
Note the hatchet also comes with a small pamphlet, a short version of the
"Axe Book" that Gransfors Bruks produces. As well I am not 100% sure I have
the "Campers Axe", the head weight does matches the specs as does the
length, however the poll is polished and curved for use as a flay poll, yet
square corners are left which would prevent such use.
-Cliff
under one cm.
Ref :
-Cliff
