I'm not a knife designer, but if looks dictate use, the wharncliffe blade excels at cutting and thrusting. Obviously not everyone agrees because most blades are not wharncliffe, unless there is another reason, and that is that bladesmiths do not want to sell them because they are dangerous weapons, like spikes, which also are not sold that frequently. (We're talking knives here...and I cannot think of any reason myself.)
Poking around looking at wharncliffe blades and I noticed that most are under 4 inches in length. That I could find, the longest folding blade was 4 inches long, by Hinderer for $600 (reasonable length, but the cost is steep) and I've not found any over 4 inches that are straight blades.
What is the longest fixed blade wharncliffe that you know of?
Are wharncliffe blades difficult to manufacture, and if so, what is the failure rate (a guess) of their manufacture and how does it compare to non wharncliffe blades? I'm assuming that manufacturers dispose of some percent of knives due to a failure of one sort or another.
I agree with this from my limited experience as well. If I am going to be using the point "that much" and it would be for something like boxes, I would just grab a utility knife for those more intensive knife use times.My limited experience... I like the Wharncliffe style for when I need to puncture and slice into flat material, like a box without a backing contacting the point.
I like the belly on a knife for carving things like wood, or cutting the skin off of chicken, where I want the small area of material in contact with the cutting edge, but not the point.
For cutting on a cutting board/block, the downside to a Wharncliffe style blade is that the point sees a lot more use and is worn down faster than the other parts of the blade (unless chopping). Since a box cutter has replaceable blades, I don't have to worry about the point being re-profiled, or sharpening off unused metal on the straight unused part of the blade after prolonged use. Just my opinion.
The classic wharncliffe is not made for stabbing.
