Oregon Duck asked a similar question on Sept 25, 1999, but I cannot find the link through the Search engine. Anyhow, here is my reply to that thread, along w/two others... FYI
Glen
storyville Member
posted 25 September 1999 02:46 PM
Well, just about *any* blade design can perform *any* task to varying degrees. I don't like tantos, but I'm sure they'll do fine for paring apples and opening boxes. On the other end (more sobering and unfortunate), thin cheap-steel kitchen knives are used for defensive/offensive purposes far more often than all other knives combined, "tactical" or otherwise. Also, I remember, as a kid, gutting fish and skinning a rabbit w/a SAK.
That said, the Wharncliffe seems pretty nifty for daily tasks. Since the edge is aligned w/the bottom of the handle, as Lynn Griffith noted, the entire blade up to its point effectively pull-cuts/drags thru its object. (More like an inverted straight pt rather than drop pt, actually.) On drop pts and such, the tip consistently falls away from the material youre pulling thru. Again, the extra effort it causes isnt really noticeable, and certainly wont cause carpal tunnel syndrome or something; so it probably comes down, as it does in many cases, to preference.
On Wharncliffes, thinner the blade, the better, IMO. Since the spine comes down to the edge rather than vice versa, you end up w/a low, very thin pointy tip. Which is why it is probably the best for pulling out splinters. You wouldnt want to stab trees w/it; but it pierces boxes nicely, and is great for opening packages, mail, and such, as its tip can be easily slipped under tape/ paper/
cardboard and cut from below, w/o damaging contents by cutting open from above, etc.
Europeans seem to favor the design a little more. Klotzli (sp?) makes a true wharncliffe folder (w/partial serrations), but a good inexpensive folder is the AG Russell Featherweight. It has a modified Wharncliffe in that the edge has a very slight belly -- nice touch, IMO. Underrated pocket knife, only $35 or so.
Boy, Im procrasting... My .02 -- Glen
______________________________
Lynn Grififth Knives Senior Member
posted 26 September 1999 01:27 PM
Storyville, You are right about them being great for slivers. However there is one better for slivers. It is the "Sliver" on my website. It is not a standard model. It was designed for and ordered by JerryO a forum member. Take a look. Thanks,
Lynn Griffith-Tactical Knifemaker
Winner of "Best Tactical Knife" at 1999 PKA show
See my award winning "Spec Ops Tanto" in Gallery 3 of my website
GriffithKN@aol.com
Discounts to Police and Active Duty Military
Corduroy Senior Member
posted 26 September 1999 01:47 PM
I see the Wharncliffe as a fine "gentleman's utility" blade style. This is because it emphasizes tasks that use the point, but has no belly for heavier cutting.
What tasks use the point? Aside from the splinter-picking and such already mentioned, a lot of drag-cutting of thin materials is accomplished with just the point and very last bit of edge. Imagine clipping coupons on a hard surface, or opening the tape on a package without damaging the contents. For knife with "belly," these tasks involve rotating the handle and wrist upwards in an
awkward manner; a Wharncliffe brings the point down and lessens this effect.
I don't agree that a straight-edge is best for pull cuts. It may be better than a curved edge, but a reverse curve or hawksbill is better still. I'm also loathe to give up the belly on a piece intended for thrusting - the belly increases the wound channel easily, much better, IMO, than the effect of the unsharpened curved spine of teh Wharncliffe forcing the edge down.
Basically, you want a curved belly and a "standard" shape for a lot of heavier knife tasks, from skinning to cutting thick cardboard (see "The Book of the Sword" for a simple explanation of the advantages of the curved edge). But for a gentlemanly knife that will be performing more light, point-oriented tasks, a Wharncliffe is a super choice.
-Drew Gleason
Little Bear Knives
