Julian you sure did,but maybe Uncle ordred some extra,I don't know.
This one isn't in the regular line up,but I think it should be.
It is a wonderful little ladies knife and just right to slip in a pocket too.
This was a special order that had several takers.It was done back in June.I think the 21st.is what I have in my log book.Mine is 9 & 1/8"
from point to top of butt cap & 9 & 3/8" from tip to tip.It is 1 & 1/4" wide.The scabbard has a brass fitting around the top of it that is 1" wide.Kinda sets the whole thing off.
I got mine in with the 27" Banspati.
Talk about the long and the short of it.
My fe-mailman has been having this strange look on her face when she delivers the boxes from H.I.
I asked her if she wanted to see one of these,thinking it might be my Ganga Ram.I opened it up and we ooohed and aahhed over tha Banspati ( I said something about the pronunciation of Kami and said it was like the Cherokee (a) and she said,"Yes,I understand." I think I have another Cherokee mail deliverer.) and then I looked in the box and here was a little something wrapped in bubble wrap.It was the CBCK.
She was quite impressed with both of them.
This little Khuk was razor sharp right out of the wrapping!!
If the dayum-ed board was working like it shouid I would go back and see who was having problems with the karda & chakma being loose.
This might help.
I had two problems with my scabbard.
The Khukuri was very,very tight.I thought."Now how am I going to loosen this one." It was easy.I took the karda from my 18"AK and stuck it in along side the little Khuk and then another thin blade in along with it also.I kept working with like that it until it was just right.It seems the brass will stretch some too.
The other problem was the little tools.I found that the tacks used are the same as for big scabbards and one was sticking way up.I tried to get it on through,but the Khuk was interfering with it.I removed it and super glued the little piece of leather down.Problem solved.
Hope that helps.
>>>>---¥vsa---->®
If you mix milk of magnesia with vodka and orange juice do you get a phillips screwdriver?
Khukuri FAQ
