What am i doing wrong. maratac band/gshock..
What am i doing wrong, The watch sits up off my wrist, Is metal loop on that second flap under the watch supposed to go under the watch on the other side of the adapter?
I think that your G-Shock adapter is making it sit higher. If you use the non-Nato strap with the adapter, it works better.
You could also cut the bottom strap off and use a lighter to seal the rough edge after cutting it. You don't need the second strap.
I use the Zulu 20mm single straps on my G-Shock adapters.
Thanks everyone for the info..I'll check out the links tomorrow,,,Bedtime now have to be up at 5;45
adapters? well ok now I need to find some of these, my Gshock needs a new band, 1SHOT1KILL, I appreciate the links!
