I took apart my sebenza 21 to clean and lube it, when i put it back together it has blade play and moves side to side when the blade is closed. also im pretty sure its not centered.
wow, cant believe such a small misstep can cause this problem. I was inserting the blade wrong. I was pulling the lock bar back and putting the blade in, not sliding it in then pulling back.
Sometimes, the bushing sticks out from one end just a tiny bit more and throws the blade off ... if that happens, remove the blade, adjust and assemble again. There shouldn't be any light between washer and scale (both sides).
