Hi, brand new to sharpening here and I just got a brand new Recon 1 spear point and a DMT Dia Sharp Fine stone. I started off sharpening free hand and found that I suck so bad that I ended up with two angles on my edge bevel, a sort of unintended micro bevel from the middle of the edge bevel going to the apex. Thats when I decided to get the DMT aligner to help me get a consistent angle. The left side of the blade looks fine and is coming along nicely. However, for some reason, with the same setting (3rd notch) on the aligner for the right side, the width of the edge on the right side is approximately a full millimeter thinner and the angle looked bigger. I dropped the setting on the right side one notch (2nd notch) and ended up with a similar width on the edge as the left side but it is not uniform and is wider by the curve of the belly. I dont know why the edges would not be uniform on an equal setting and why I had to drop the setting down one notch on the right side to get a similar width on the edge. It doesnt make sense to me but it worked, sorta.
Before I dropped the aligner one notch on the right side, the knife wasnt cutting paper cleanly and after I made the adjustment, I saw an improvement in cutting paper. Much cleaner and effortless cutting. It still doesnt shave hair but I dont know if I can achieve that with the Fine stone. The knife shaved hair from the factory. Thoughts as to what is happening here and what Im doing wrong? I do a choil to tip edge leading movement. I reset and do the same motion. I dont go back and forth as I find its harder for me at this point to keep it consistent if I try to go back and forth.
P.S. I know I need to work on my movement when it comes to the tip of the knife.
