What angle do you folks sharpen your Sebenzas to?
Right now I have a 20 degree bevel on my S30V (RC58-59) small classic Sebenza. The toughest stuff I cut is usually plastic zip-ties followed by cardboard.
Q1: Do you guys think the edge would be too weak if I took it down to 15 degrees per size? I'm mainly worried about rolling the edge, especially with thicker plastic zip-ties.
Q2: What bevel angle and blade material do you guys have your Sebbies set up with?
40 degrees won't cut well at all.I don't go above 30 for my knives.
Not sure. I free hand sharpen mine and thinned out the factory angle just a bit. Whatever that angle is, it works well for me.
34* Is perfect for me on all my knives (I free hand sharpen with mine and realized I sharpen at that angle after some measurement)
I also free hand sharpen on a Japanese water stone. Not sure what the angle is but it would be no more than 15 degrees each side (possibly less).
I also thinned the blade a tiny bit to help it slice better.
Now is just gets touched up from time to time and mostly stropped on leather or sometimes I strop it on the fine stone
All my knives are at 30 degrees inc. or less. 40 is a bit thick for my tastes.
If you want something to go through those zip ties like a laser, get it Krein'ed at about 8-10 per side. :thumbup: Just don't twist it while you're cutting.
I spent years and years and years carrying a couple of sebs sharpened to 30 inc (sharpmaker)... I have not noticed much difference between them and 40 which is what I do now... I reckon IF I sharpened as much as I did then, I would not be happy with a 40deg edge with ZERO backbevel, but I have not had any probs with a 40 deg initial edge, and a factory backbevel... which is probably around 30degs... of course, I mainly use Spydercos now... I'll be pickin' up another Mnandi now since I've been using some smaller blades, and I was just not hip to its size back in the day. I will check the edge to decide then... I might just end up toughing up on the 30deg side of the Sharpmaker to avoid heavy sharpening to achieve the backbevel... who knows... sometimes I just get lazy and the 40 deg side certainly makes faster work of touch ups...
I free hand on DMT benchstones keeping as close to the factory bevel as possible, but always err towards thinning the edge, rather than widening it. I've sharpened my Sebenza perhaps 4 times over the past 1 1/2 years and the bevel looks pretty much exactly the same as new, just a little more polished than the one from the factory.
I also lowered the angle of my sebbie, and at first I didn't liked the big bevel.
So I advice you to take it slow!
Marthijn
Would 30 degrees on a sharpmaker be roughly the same angle as the 30 degree setting on a lansky?
^ jz 4020
No it is not the same. 30* angle will give you an edge at 60* as the 25 gives you an edge of 50* If you want a 30* angle as on a spyderco sharpmaker you need to sharpen at a 15* hole of the lansky. (the sharpmaker says 30 but each rod is at an angle of 15* to give you an edge of 30*)
I use the 25 hole on the Lansky and strop afterwards. A bit finer than what came from the factory.
