Hi,...if I handed you the pictured knife, and asked you to measure the angle it was sharpened at... would you measure from an imaginary centerline that ran straight thru the blade... and disregard the blade grind angle? (Might have been the easiest way to ask this).![]()
Hi
Yes, it dependsbasically what the other guys said
Consider that under 15 dps edge can chop bones
And 12 dps edge can still shaves/whittles beard hair after 1000 slices of hardwood
So if you're chopping rocks and bricks, 25dps might resist damage better than 20dps,
but if you're slicing stuff, 25dps dulls faster than 20dps even if those are microbevel angles
So, recommendations for 25-30 degrees per side sharpening angle
are great for first time sharpeners or if you only have seconds and need results quick,
much better than a dull knife
... but try and do a couple hundred slices with that edge angle ... ouch![]()
