I should mention that I'm currently using a Ken Onion Work sharp.
Super easy way eh? Almost cheating
All joking aside, if you turn the angle down, I don't know if you can put it in between the 15 and 20 degree marks, if so try around the middle of them. A microbevel will add a bit more strength and life to your edges.
Why is everyone using a super steel at 40 degrees inclusive? Your robbing yourself of the performance the steel has to offer.
Might as well be using AUS8 or 8cr.
Edge angle is key to a good cutting edge and having good steel with a good heat treatment allows you to reduce that inclusive angle while not having the deformation and rapid dulling found with lower alloy steels.
Spyderco grinds the blades thin and runs the steel hard, compliment these features and give it a thin cutting edge.
Agree with this 100%. Spyderco M4 for me goes no more obtuse than 15 dps. I even run my S30V PM2 at 15 dps, and if I ever detect any slight rolls, a few minutes of stropping fixes that right up. I plan on trying out ZDP one day and won't run it anymore obtuse than 15 dps.Why is everyone using a super steel at 40 degrees inclusive? Your robbing yourself of the performance the steel has to offer.
