- Mar 30, 2006
I use a lansky sharpening kit to sharpen my knives. What would be the best angle to use for my tactical knives? Thanks.
Well, since you have the Lansky and are restricted to four angles I would use the 20 degree setting. It will work well for you.troutfisher13111 said:I use a lansky sharpening kit to sharpen my knives. What would be the best angle to use for my tactical knives? Thanks.
Thanks. I'm sure this would work but I like to freehand sharpen as simply and quickly as possible without making too much of a fuss about it. I'll go with what you said here:HoB said:Mtn. Hawk. Sure you can do a multibevel by hand, just get a protractor to get a feeling for the angle or use some coins to lean the spine on.
Good point. I have seen this mentioned before but had forgotten it. Thanks for reminding me.You don't have to get the transition of the multibevels sharp. Freehanding is likely going to round the bevels over a bit so that you actually end up with something like a convex edge, which is just as good, if not better.
Mtn Hawk said:Since the subject of big chopping knives was mentioned, what angle do you suggest?
12 degrees primary and 15-20 microbevel.
troutfisher13111 said:My knives are used for everyday use. Cutting rope, boxes, opening packages, splitting small wood,carving, cutting small branches, opening cans. Maybe a little prying.
It's very interesting that you still got fairly good chopping performance with your Battle Mistress at 8/12, even though there were some restrictions. I really thought I was making a mistake taking the Battle Rat down to about 12/15 but the only way I could find out if it worked was to try it. So far I'm very happy with the results on hard, dense, dry lower branches of fir and pine. Even on dead manzanita, the hardest wood I know of around here, it's holding up. I'm going to do a few more hours of chopping with it before I am confident I can leave it at those angles but so far so good.Cliff Stamp said:The thinnest I have gone was 8/12 on a Battle Mistress, this would cut most woods, but the edge would turn at the level you would see visible deflection on harder knots so the edge retention was low on poor woods and you would not want to use it for any difficult batoning with that profile.
Great point about increased penetration reducing shock and fatigue. This is something I don't see mentioned often but I think it's very important, especially in wilderness emergency or survival situations where wood chopping is often the most time- and energy-intensive work one does.Yes you can gain a lot in chopping performance, 50% was about what I saw on the Marine Raider bowie as well. Aside from the raw penetration you also influence shock and fatigue which make a big difference in extended use.
Wow, I never thought about that! Another great point! Thank you for bringing it to my attention.Ironically the edge often gets more durable for wood work if you reduce it, it isn't actually stronger, but the cutting ability tends to reduce impacts and lateral loads to such an extent that the edge retention increases. Up until the point you miss the wood and hit something else anyway.
Mtn Hawk said:I really thought I was making a mistake taking the Battle Rat down to about 12/15 but the only way I could find out if it worked was to try it. So far I'm very happy with the results on hard, dense, dry lower branches of fir and pine. Even on dead manzanita, the hardest wood I know of around here, it's holding up. I'm going to do a few more hours of chopping with it before I am confident I can leave it at those angles but so far so good.
I can understand inferior knives having thick edges to make up for their deficiencies but I don't know why high-quality knives also have them.
I never considered there might be a difference in forces between batoning and chopping. I have not tested the 12/15 Battle Rat with batoning but will do this. Hopefully it will stand up to heavy batoning at this angle (as you said, steel can't be put back on). I think the Ratweiler blade is the same as the BR, only 2" shorter, but not sure. Almost all the firewood around here is very hard, dense fir and pine so I don't have much of a choice in what wood to cut.Cliff Stamp said:The Ratweiler I have was stock at 0.035" x 20 degrees, that is about perfect for that goal. For pure heavy wood work this could be cut down to 0.030" x 15 with a 20 degree micro, moving under this would risk failure on heavy batoning. Without batoning you can really slim out edges as it puts much more force across edges of lighter blades than chopping when you are working in problematic wood, which also brings up the point do you want to be able to cut that class of wood or not.
Mtn Hawk said:I never considered there might be a difference in forces between batoning and chopping.
Cliff Stamp said:The Ratweiler I have was stock at 0.035" x 20 degrees...
-Cliff
gwb said:Is it the the horizontal distance (knife held vertical), from the intersections of the primary and secondary bevel on either side of the knife?
