I snapped a few quick pics here to show how I use the angle cube on the edge pro, not sure if everyone else does it this way, but it works for me.
I think it would be more accurate if you placed the knife on the EP and then put the angle cube on the stone holder as it lays on the edge of the knife, but this has worked for me for years?
First I zero it out on the table, then place it on the stone holder and adjust it to the angle for each knife needing sharpening.
When you sharpie the knife, make a pass or two and it should remove most or all of the sharpie in that area. (Keep in mind that on your initial sharpening it will only remove sharpie from the middle-lower area of the edge since you will be working with a convexed edge, this one already has a v edge on it so it took it all)
And the last photo demonstrates that if you place your knife in a different position or depth on the table, the edge of the hollow grind will be at a different angle on the table, adjusting the final edge angle you will be sharpening at, so I scribed the edge of the edge pro table to make sure that it gets put at the same spot for sebenzas, which now I just leave it there since that is all I have, but if you are going to be sharpening other knives, you'll want to get it setup the same each time for consistency. Like with the small sebenza shown, I would have to move the fence out to get the edge of the blade hanging over the edge of the table. So having the mark on the edge pro machine allows you to move the fence back and forth for diff blade sizes but still be able to get the exact spot (or fairly close) for subsequent sharpenings.
