What are kershaws thicker blades?
Using the ever so accurate eyeball test (I don't own calipers) I'd say they are more in the .125 range (both the Boa and the Spec Bump) as compared visually to the Benchmade 790 Subrosa, I have sitting em all side by side...
Hope that helps,
-Jack
besides the Tyrade what Kershaws have a blade thickness in the .150+ range? Spec Bump? Boa?
The Tyrade is about the thickest Kershaw blade I've seen. I'd have to compare it to the Volt and Speedform to see where they stand in thickness, but I think to get anything thicker or as thick in as the Tyrade you'd have to move up to the ZT line.
There some room for error in this sense I'm using the same eyeball test that Thingus995 is using. :D
I'm not sure which models have the thicker blade stock, but I don't believe there are many. I suspect they tend to save that for the ZT line.
If it helps, I know my ZT 0302 is .156 while my 0350 is .121, so using that as a guide, my Tyrades look about the same as the 0302 and the Spec/Speed Bumps and JYDII CB look about the same as the 0350.
Using the eyeball test because I'm too damned lazy to run downstairs to the garage and to get my micrometer I see that the Ti Tyrade, Speedform and Volt are all right about the same blade stock thickness. All very beefy.
I also noticed that the ZT 350's blade is quite a bit more thin than the other three listed above.
