Do NOT buy a cold steel... broke it clean after 2 days of bending it back to straight...
Do NOT buy an Ontartio unless you intend to make using the machete a "workout" for you arm...
spikebot587 has a great point with the Tramontinas, they are a good machete.
But I have to agree with marcinek.
I surveyed for a decade in north Florida and have cut thousands, I mean miles upon miles of "lines" through the woods. I have used machetes ranging from 16" to 28" and from $7 to $35.
For general work I would recommend a 24" martindale "alligator brand" machete with a wooden handle. They are made in England. You WILL have to reshape the handle or you will get blisters. You WILL have to put a new handle on it after the original one wears out and cracks. You WILL be surprised by how thin and flexible the blade is. This is a TOOL. It is not pretty, but if you carry a small file in your back pocket, you can cut ALL day with this machete. I have many times.
You remember your grandmothers old paring knife that was only half there after 29 years of use and sharpening and use and sharpening???
I had my first alligator for 5 years and it went from 24" long and about 2.5" thick (at the thickest point) to 19" long and about 1.5" thick before I gave it up for a new one. I regretted that for an entire month as I broke in the new one.
I can get them locally in FL for around $20. I'm sure they can be found on the WWW for cheap.
Buy whatever "cool" looking machete that pleases your eye... then drop $25 on a martindale and compare the two... let me know what the results are...
In the end I hope you find exactly what you are looking for.
And safety first.
- ALWAYS clear your back swing area before working forward.
- ALWAYS cut elbow to thigh/knee area.
- If the elbow of the cutting arm gets to your thigh/knee area before the cut is completed, you can (almost) NEVER cut your self. The machete will hit the ground before it hits you.
This advice is the result of 20 something stitches over the course of 3 different "incidents", so take it. Oh... and keep that SOB sharp, always.
