it makes my ocd hurt.
I don't know a lot about this, but noted while shopping for a Japanese Chef's knife a while ago that many of the blades are intentionally sharpened with an asymetric bevel. Some were sharpened to target a 50/50 grind so that the blade cuts the same with either hand, but many I saw were offered with a 70/30 bevel that was specific for either left or right hand use.(Mostly right hand of course, with left hand grinds available on request.)
I've never done any comparison cutting to see what kind of effect this has, but I do find it interesting. I guess the con would be that if you're using a knife with an uneven bevel that favors your non-dominate hand, the cutting performance will suffer. Not sure that I would be able to tell in use. I certainly haven't ever been cutting something and picked that out as a factor working for (or against) me.
Title says it all.
Most people buy knives for both aesthetics and function, and severely uneven bevels can detract from the appearance of a blade enough that an owner might be uncomfortable looking at it.
That said if a blade is handground it likely doesn't have perfectly even bevels and for these knives a small amount of unevenness is desirable as proof of being hand ground.
The closest anyone gets to truly even bevels in a hand grind in my opinion is Walter Brend.
Uneven bevels can cause a bias in the direction the knife cuts. Cutting efficiency will be different depending on the direction of your cut and the knife may have a tendency to steer one way or the other.
It enables very low angle cuts to be made and with reduced deflection on the interior face of the blade.
