Same as above ^ but minus the strops and Diamond paste unless you have some knowledge in stropping. For $20 bucks on ---zon you might want to think about one of those work matts if you plan on doing regular knife servicing . Some of them come with magnetic spots that come in handy for keeping screws off the floorZippo lighter fluid
Acetone
Rubbing alcohol
Wiha torx bits 2 of each and two drivers. (or other high end bits)
Grease and or lube.
Sharpening stones.
Strops and diamond paste.
Q tips and shop towels
Heat gun for locktite
Acetone or zippo lighter fluid to remove old lubrication, alcohol to clean scales (alcohol can work to clean old lube but takes more tries and scrubbing).
If you have any resistance loosening screws just stop. It likely has locktite. If you try and budge it, it will likely strip a screw or your bit. Use a soldering iron, heat gun or boil the knife in water to loosen the bond. There is also a method to shock the bond loose.
This isn't exactly true. Sure if you don't care about removing all the previous lube this is fine. But you will still have lube on it. And for some this doesn't matter in the least. However it matters in some situations. Like if you have lockstick from lube on the lockbar or tang. Or if your chasing that super action on bb flippers. Nothing to worry about otherwise. But applying lube and wiping it off is probably the correct amount of lube for knives. Plenty of lube is still there. You can't get it all off without dissolving it.and oil and grease wipe right off
sory Mo2, that was a bad sentence on my part. I meant that oil and grease wipe off the work matt easley. I hope nobody unlubed their knife after servicing because of that so I edited it.This isn't exactly true. Sure if you don't care about removing all the previous lube this is fine. But you will still have lube on it. And for some this doesn't matter in the least. However it matters in some situations. Like if you have lockstick from lube on the lockbar or tang. Or if your chasing that super action on bb flippers. Nothing to worry about otherwise. But applying lube and wiping it off is probably the correct amount of lube for knives. Plenty of lube is still there. You can't get it all off without dissolving it.
