I own a couple of larger folders myself (let's consider "large" folder as those with blades approaching 4" or greater), and like them. My Spyderco Chinook 3 is one of my all-time favorite folders.
However I've been thinking lately about this: With large folders, why pay the added costs in $$$, the extra weight penalty (due to locking/opening hardware), and the reduced reliability of a folder? Instead, for folders why not just stick with small to mid-sized folders for EDC/pocket type of use, and for any blade in the 4" or larger vicinity, just get fixed blades?
Here's an example of the size/value proposition between a typical large folder, and an equivalent sized fixed blade in the same brand. Price quotes are from (( not a BF Dealer member )), for consistency. This is just to illustrate the general concept that when you get a large folder, the overall value proposition, when you factor in cost, the weight of the knife, etc., tends to favor the fixed blade. Note how the Benchmade Adamas fixed blade is thicker, longer, stronger (no lock), and costs less. This is quite typical:
Adamas Fixed:
- Cost: $119
- Steel: d2
- Blade length: 4.2"
- Blade thickness: 0.170"
- Weight: 5.6oz
Adamas Folder:
- Cost: $165
- Steel: d2
- Blade length: 3.82"
- Blade thickness: 0.160"
- Weight: 7.7oz
And here's another example, comparing the beefy Zero Tolerance Strider fixed knife (a 4" fixed blade for military users), with the beefy ZT 200 (perhaps their most beefy 4" folding knife, also made for military use). Here, the cost is higher on the fixed blade, but that is presumably because it uses a higher-end s30v steel, and a lot of it (since it is 0.25" thick). Otherwise, the overall value proposition again favors the fixed blade. Once again, the fixed blade has a MUCH thicker blade, and longer, in a higher-end steel, but it weighs only 1.4oz more, and costs only $40 more.
ZT Strider fixed:
- Cost: $199
- Steel: s30v
- Blade length: 4.25"
- Blade thickness: 0.25"
- Weight: 9.1oz
ZT 200 folder:
- Cost: $160
- Steel: 154cm
- Blade length: 3.875"
- Blade thickness: 0.156"
- Weight: 7.7oz
Bottom line that you can see illustrated with both cases above: If you're going to carry this much weight (over 6 oz for a knife) and go to this much expense anyway, the fixed blade appears to be the better "bang for the buck." You get a thicker, stronger blade, in the same or longer length, and cost is basically lower if using the same steel type and quantity.
Here's why I've been rethinking all this. Except for a tactical/defensive advantage, it's hard to see in my case what carrying a large folder really gains me. It's more expensive, it adds a ton of weight, but it's still less reliable than a fixed blade due to the locking mechanism, so it's still not really great for hard/survival type use. It adds length, but usually not ENOUGH length to make a huge difference over lighter, thinner, shorter EDC types of folders that are in the range of 3.4" to 3.6", such as the Spyderco Para Military 2. It's probably a bit easier to carry a 4" folder than it is to carry a 4" fixed blade, since that size of fixed blade requires a sheath and won't fit in standard pockets. So I will grant that point. But aside from that ONE advantage--the ability to carry the slightly larger folding blade conveniently in a pocket or whatever--I cannot see much practical advantage to carrying a large folder. They just aren't giving you that much more performance than their mid-sized folding counterparts. And if you are talking survival or hard/use, you definitely want a fixed blade anyway.
I'm just thinking out loud here, not trying to bash large folders, which I enjoy as much as anybody. Somebody chime in here and convince me why large folders are still useful for more than defensive use, and why they still deserve a place in your kit. Why is it still useful to carry a large folder, rather than just carrying say a medium folder for EDC, and then adding a 4" or greater fixed knife for hunting, camping, survival pack use?
Adamas Fixed:
- Cost: $119
- Steel: d2
- Weight: 5.6oz
Adamas Folder:
- Cost: $165
- Steel: d2
- Weight: 7.7oz
ZT Strider fixed:
- Cost: $199
- Steel: s30v
- Weight: 9.1oz
ZT 200 folder:
- Cost: $160
- Steel: 154cm
- Weight: 7.7oz
