So, someone correct me if I'm wrong, but I think there is another option here.
Convex edges can be given to any knife. You will just be re-grinding/sharpening the secondary bevel from a "flat" angle to a convex angle. You can do this by sharpening on a surface that has some "give" to it. I've used mousepads and wet/dry sandpaper to give this edge to a few of my knives, and it seems to work great.
Then there is a convex "grind" which NOT something you can change by sharpening/edge work. The convex grind then is the whole primary grind of the knife. So for that you would likely need to start with a convex ground knife.
So depending on which one you're talking about, you might not need to buy new knives (unless you're just looking for a reason to buy some
). And I actually don't know the bark river knife models very well, so someone else will have to help you out with that.
