I'm using a belt rather than a stone because I need to peal off upwards of .025 per side in a production setting which is outside the scope of most stone wheel surface grinders. The belt runs much cooler and can take much deeper cuts. However, being a regular automatic grinder it is limited to .002" down feed per pass even though the belt could take much more. So, I'm feeding it over much more per pass than a stone would. I'm roughing a 10X20 table load pealing .002 at about 100 IPM and feeding over 1/4" per pass. It only takes a few minutes to rough in the full table load. I reduce my depth of cut to .001 and the step over to 1/8" for finishing and have it set to three spark out passes on the finish belt.
Something that's surprising to me is I appear to get very little heat this way. Very little sparking. The swarf is shiny and bronze colored. I figured I'd need to run coolant but we're just running it dry. The chips from the roughing cycle are pretty heavy, it almost looks like coffee grounds piling up. The finishing cycle generates regular dust, though it still doesn't spark much.
Something I struggle with is belt wear which can erode faster than the work. If I need .005" I need to dial in at least .010" on the finish belt. The work piece thickness is consistent across the table, in part because I'm going across the table so quickly and because the belt is pretty wide. The belt erodes a little more on the edges and the center of the belt is doing the finish work on the spark out passes.
I have been able to avoid striping and choppiness and can dial-in whatever surface finish I want simply by changing belts. Part thickness is very consistent within a batch, but can vary from one load to the next depending on how well I dial it in. Right now if I get the part thickness I'm aiming for to within . 001 I call it good so a run might vary from .187 to .189.
