Between 10-12 deg per side usually but not always with a microbevel of +(3-5) deg. The reason I usually don't go lower is because it becomes more and more work. The material that you have to remove increases very nonlinearly. Only my Pacific Salt I have taken below 10 deg, but H-1 is very easy to grind. My RD-9 I left at 15 deg per side, because I experienced failure at 12 deg. My axes I try to keep around 20 deg per side or lower, convex without microbevel. Much more difficult to measure an angle on the axes, so I mostly eyeball it and check later. I draw up a profile (just under 20 deg per side terminal angle) on a piece of paper first and use that as a reference.
