i dont undestand what you mean by this please exlain it easier?Peter_E_Ryt said:Take the blade and draw an outline on it- don't forget the tang. Then take a drill and drill around the outline of the blade (don't forget to have it clamped down!), take the hacksaw and cut out the the blade blank now. Then, file off the rough bits left from the drill holes, file the bevels, and take sandpaper to finish it off and give it an edge. I found this on a tutorial floating around the web. The only difference is that I had a drill press.
ajcz said:i dont undestand what you mean by this please exlain it easier?
new knifemaker said:you guys have helped me to get motivated. how can i find bar stock that will hold a temper make it simple, i an 14
ajcz said:what are some things around the house with minial tool use and wouldnt need heat treating or if it does how could i do it cheaply (mind you i am 16).
