ick. yuck. blech.
you want top shelf results without paying the market cost for 'em?
rotsa ruck. what works is a hard, consistent, stone in at least two grades..
low end 'will work' is a norton 1000/4000 combo waterstone.. roughly 50$ range..
DMT will give you a 1000/1200 grit finish on their Extra fine bench stone (though they have smaller versions for cheaper) but I don't call that even a working edge.
Belgian double-grit natural stones run 100-400$, japanese stones from 100$ to the moon.. (thousands)...
ceramic and synthetic hones aren't all that much cheaper. .the norton really is 'entry level'.
and cheap aluminum oxide stones are great.. for removing rust or flattening GOOD stones.. I own several of 'em, and don't use em to sharpen with. Strictly maintenance..
IMO the best answer is a small belgian double-grit, 1.25 x .75 x 6 .. cost roughly 100-150$ depending on your shopping skills, and the only hone you'll ever need for medium/small knives, even if you live to be 100..
and the norton will last you a year or three, not 30 or 50.. judgment call. MOST of my stones cost over 100$, and I'd suggest that spending more on a whetstone than your best knife costs makes all kinds of sense.
As well as, getting a stone big enough to finish a sharpening job TODAY.. not 'sometime'.. Belgians are fast cutting and smooth polishing both, which isn't common. DMT is fast, Japanese are smooth, Shapleighs (synthetic) are top shelf and a set is over 500$..
don't flinch at price. buy once, cry once..
