After peening the knife together? I was making this 2 blade folder, and in dry fitting everything went together straight and smoothly. I peened it, and the little blade came off towards the center. I straighter it out and the knife works great, but I'm just curious if I'm peening wrong or if that is just the way it is sometimes?
Is chamfer the pivot holes using a 1/64" larger bit, sanded into a slight cone. I leave half a diameter of pin sticking out, and tap all around the edges to form a head, and tap straight down to fill in the gaps. I do use a little shim cut from thin plastic from various packaging so I don't peen the knife shut, then I pull it out and peen so there is no side play. I notice that I always have gaps wherever the shim is, and I wonder if it is bending the knife scales enough to cause This? Is there a better way to prevent peening the knife shut? What am I doing wrong?
