Cliff Stamp
BANNED
- Oct 5, 1998
Awhile ago I made some comments about metal cutting :
http://www.bladeforums.com/forums/showthread.php?t=364976
Recently, inspired by an exchange Thom and Alvin were having on rec.knives I did some work with a 1095 paring knife, 66 HRC, 0.055" thick stock, hollow ground, edge is 0.010-0.012" thick, 0.2" back from the edge the knife is 0.021" thick.
I first used it to cut up some chicken :
http://i7.photobucket.com/albums/y269/CliffStamp/Alvin/alvin_paring_chickenhttp://i7.photobucket.com/albums/y269/CliffStamp/Alvin/alvin_paring_chicken.jpg
The breasts were cut off, the legs removed and seperated, the wings removed and the tips cut off, and the body cut into pieces with the tailbone removed. No damage to the knife, still shaved, multiple chickens went to parts when I changed to the utility knife (similar grind on 63.5 O1) which has a 20 degree microbevel so I could experiment and get sloppy and do things like :
http://i7.photobucket.com/albums/y269/CliffStamp/Alvin/alvin_utility_legs.jp
http://i7.photobucket.com/albums/y269/CliffStamp/Alvin/alvin_utility_legs.jpg
Note the cuts through the bone, plam on the tip, off hand on the handle, rock down and cut through the joint, hard tool steel is a wonderful thing. Back to the paring knife :
http://i7.photobucket.com/albums/y269/CliffStamp/Alvin/alvin_paring_bone.jpg
Carve up an rib bone like a piece of pine, I got sloppy with the work near the tip and there was some side torquing when I started to hog material off, more than 1/16" deep slices and due to the leverage issues with cutting with the tip the edge rolled a little, yeah it rolled, it didn't chip. When steel gets really thin it gets flexible even at this hardness.
Now we do some work which gets commonly gets the abuse label :
http://i7.photobucket.com/albums/y269/CliffStamp/Alvin/alvin_paring_cat.jpg
Using an icepick grip I cut one inch down into the sod to make a small rectangle. The front of the sod was then cut at at 45 degree angle so I could peel it back al little then I simple skinned it off, cutting it easily with the knife.
http://i7.photobucket.com/albums/y269/CliffStamp/Alvin/alvin_paring_hole.jpg
No visible damage, though it was blunted :
http://i7.photobucket.com/albums/y269/CliffStamp/Alvin/alvin_paring_after_so
The first inch near the blade could still do clean press cuts, near the tip the cuts were ragged and needed some back and forth slicing. I reset the edge with waterstones, no micro-bevel, <2 minutes. All of the above work was done with a primary edge bevel of 2-3 degrees and a secondary edge bevel of about 5 which is so small you can't see it, even under 10 x mag it isn't apparent.
-Cliff
-Cliff
