The Ken onion work sharp will likely waste a lot of belts on d2. I had to get the diamond belt on mine to sharpen 60+hrc d2 (Ontario rat's are around 58hrc iirc, so easier to sharpen) but the diamond belts are only made for ceramic knives. So it was basically a one use belt lol but it worked.
Not that diamond belts are needed for D2, but I've gotten good life out of my 3M diamond belts.
They have to be run at a slower speed and used with water or a thin film of mineral oil to prevent them from clogging.
Will ceramic rods work?
Hi,Not that diamond belts are needed for D2, but I've gotten good life out of my 3M diamond belts.
Hi,
Do you have more details?
What speed is slower speed (SFS or SFM)?
How many strokes/knives is good life ( 50 x 8inch, 1000 x 4inch)?
What happens once its no longer good ?
What grit ( 36? 60? 120? 240? 600?) and How does 3M trizact of same grit compare ?
Thanks very much.I use Blaze, not Trizact, so am not sure of the analog, but it cuts close to a 120 grit Blaze, maybe a touch finer.
Thanks very much.
Is there a difference in lifetime (your usage) between blaze and diamond? does one last longer than the other before you switch out?
Hmm,
Interesting,
400rpm x 4inch = 418.879 SFM /60 = 6.98131666666667 fps
500rpm x 4inch = 523.599 SFM /60 = 8.72665 fps
24 knives * 10 strokes * 8.72665 fps = 2094.396 feet
Hand sharpening speed
4 pass per second * 6-8inch stone / 12inch = 2.167-2.67 fps
5000 passes * 6 inch /12 = 2500 feet
