- Aug 17, 2009
Read title
I've used the Spyderco Sharpmaker for the past 15 years and have been very pleased with the results. I think one needs to add the diamond sticks to the set to easier profile a blade, but with time and effort the gray stones will work. I think what I like the best about the Sharpmaker is that I keep it set up on my work table and every night I will give my knives, those that were used during the day, 10 to 20 strokes on the white stones. It is much easier to keep a sharp knife sharp than to dull the knife and then try to get back that level of sharpness.
Btw sean, I saw were you asked a question in another thread about reccomending the ZT0350, and a reply stated that the blade was not centered and coming in near contact with the liner. Just wanted to tell you that this is usually an easy fix that does not require you to dissasemble the knife.
Yeah I do the same thing with mine, if they start getting dull I just give a few passes on my Sharpmaker and it's good to go.
Assuming you don't have a dedicated workshop to set up a grinder/belt sander, etc.....
'Easiest' has to be the Spyderco Sharpmaker plus diamond/ultrafine rod. ANYONE can sharpen a dull knife with one hand using this setup.
'Best' can only be made by EdgePro. No ands, if's, or buts. EdgePro Apex or Pro models will give the user a perfect edge. It doesn't get much better than perfect...
Now, if you DO happen to have a workshop where you can set up some larger machines, paper wheels, belt sanders, grinders, etc., etc., etc., there are a dozen excellent machines available on the market today that are used by sharpening companies all over the world. The first question to ask is; do you really have to sharpen THAT MANY KNIVES? If you are only sharpening a couple, do you need to set up a machine?
Stitchawl
That depends entirely on how you define perfect.'Best' can only be made by EdgePro. No ands, if's, or buts. EdgePro Apex or Pro models will give the user a perfect edge. It doesn't get much better than perfect...
