- Mar 3, 2018
Hey everyone,
I'm new here and I'm just getting into knives. So I'd like to purchase a bowie knife and I found this one for relatively cheap and I've done some research on the specs and the metals and the HRC but I'd like the opinions from the veterans. I would like to use this knife for chopping small to medium pieces of wood and also, to be honest, I think it looks really nice. Anyways, here are the specs. I look forward to hearing your say. Thank you kindly.
The 051O1 Hunter contains a high quality hand forged 4mm thick High carbon steel blade.
The tang extents far in the handle and has a U shaped piece of stainless steel welded to it. This stainless steel is visible on the sides of the handle. The stainless steel prevents corrosion from contamination from the hands. The tang construction is very strong and can easily withstand heavy chopping action.
The 051O1 Hunter is hand forged from O1 high carbon steel which is a tool steel well known for its high toughness and excellent edge holding capabilities.
The blade has a mirror polished finish for a smoother cutting experience.
The knife contains a clipped point which is a typical characteristic of a Bowie knife. The clipped point allows for precise cutting.
The handle is made from 2 pieces of stag horn combined with a Brass guard and pommel to ensure a good grip and unique look. The guard and pommel extrude far enough to protect the hand during use of the blade.
The knife comes with a leather sheath that can be worn Vertically on the belt. The sheath includes a utility pocket for a small sharpening stone. We can supply the knife with or without sharpening stone fitted (select the order options).
The 051O1 Hunter has a serrated edge on the back of the blade that can be used as a saw. However, this is not a replacement of a saw it is ideal to create small grooves. The front of the blade contains a sharp cutting edge, the blade is thick and strong enough for heavy chopping action, this combined with the clipped point make this knife an excellent multi functional survival tool.
The cutting edge comes razor sharp!!!
An excellent highly durable hunting knife!!!
SPECIFICATION:
The blade is properly hardened and tempered with classic methods and the use of quench oil. The Rockwell hardness is about 54-58 HRC. These knives are batch tested on hardness so the hardness might vary slightly between knives because these are hand crafted and unique.
54-58HRC is the ideal hardness for this type of steel and knife as with extreme impact (hitting a rock with a lot of force) the blade/edge will not chip but instead bend. This is in most cases fixable. If the blade would be any harder then it is more likely to chip or shatter this will make the blade unusable which is not ideal in a survival situation. If the blade would be any softer it won't hold the edge long enough.
Every knife is handmade and unique. Damascus patterns and size will vary slightly between knives we can supply pictures of stocked items upon request.
SPECIFICATION:
- Overall Length: 32.5cm
- Blade Length: 19.5cm
- Blade width: 3.7cm
- Blade Thickness: 4mm
- Handle length: 12.5cm
- Handle Material: Stag horn
- Guard/Pommel: Highly polished brass
- Layers of Carbon Steel: 224 Layers
- Steel: O1
- Hardness: 54 - 58HRc
