- Apr 24, 2009
Hi,
I have recently got a small Sebenza 21. As great as the knife is it did not arrive sharp and the edge bevel was quite a bit more than 40 deg. So I used my sharpmaker with CBN rods and after 1 hour of work I got it to 40deg. I am not too crazy about that. 40deg would be fine for micro bevel, but the edge bevel is rather wide so I would like to thin it further. Obviously - the sharpmaker is not the way to go (I do not blame it for that, it was simply not designed to remove larger amount of material).
I have a full setup of some of the best japanese water stones (Gesshin) and can use them reasonably well, but I do not want to risk getting some of the slurry inside the pivot for obvious reasons. Therefore I am looking for an alternative.
I am not quite ready to invest 100+ euro in some sharpening system (I had KME and gave it away when I got into kitchen knives), though I would consider something like DMT Diafold MagnaGuide as I could then also use the diafold free handed. I have heard (from the seller here in DE) that this guide should be able to go as low as 12deg. per side - that would be great, but I am not sure that is correct. Another option would be a s simple DMT stone (probably the coarse one). Simple diamond stone would be more flexible, but would make it much easier to put unnecessary scratches on the blade.
I would appreciate your input and experience. Thanks.
