- Mar 19, 1999
I just heat treated my first batch of 0-1 blades. I heated them in my bbq, and quenched them in vegetable oil. I did ten blades like this. I have one blade that has been my test blade, becuase it turned out really ugly. Any way here is my story. I tried to heat treat this blade with a torch 3 seperate times, and it didn't ever work right. The first time I tested the blade I tried to pound it through a 16d nail. It just got all deformed. The part of the blade closer to the tip deformed a lot less then the portion of the blade closest to the handle. I tried it in the bbq today, it was red hot, and non magnetic, after I quenched it I tried to pound it through the nail again. This time it would cut about halfway through and then the edge would chip off, I figured this meant I had successfully hardenend it. Then I did the rest of the blades in the same manner. I then put them in my oven and 425 for 1 hour, then let them cool to room temp, then I put them back in at 425 and left them for about 1 1/2 hours, because I fell asleep. I tried to pound the same knife through the nail again. I hit it on the spine very hard with a 23oz framing hammer, and the blade broke in half in almost a straight line from spine to cutting edge. I lost about a 2" portion of the blade, I then took this portion and pounded it in to a peice of wood tip first about 3/4" into the wood, then I smashed the remaining part of the blade peice sideways with a hammer, and it came out sidways exactly the same as it looked when I had pounded it in, then I did it again and i broke off a 1/4" peice of the tip. I then pounded on the spine of the remaining peice and it split the wood like a chisel, and I could not break it anymore. I pounded the chunk back through the nail, but because I had to hold it with my fingers I couldn't take full swings but it did cut into the nail and it didn't chip or deform. The knife was 1/8" stock with a hollow grind made on a 8" wheel. Should the knife have broken apart the way it did, or is there something wrong with my heat treating.
sorry about the long post, sorry it it is hard to follow, I am very tired right now.
thanks for any help
Kyle
thanks for any help
Kyle
