Half of my shop is in half of the garage.I keep 2 Dremel 395's or Sears equivalent hooked up there...use sanding cylinders on final profiles on liners, blades, etc, use the cutoff wheel to cut slot for the lock part of the Ti liner. use reinforced cuttoff wheel as a mini grinder...to shorten screws a small bit. also cut off pivot pins and removing any excess metal around a drilled Ti or Steel hole. cut screw slots in torx and pivot pin heads. Also profile cleanup on the inside of Ti or Steel or micarta spacers. Also to grind the face of the lock on the linerlock when hand fitting the final bit.
Other half of my shop is in the house...back room.Keep 2-4 Dremel 395's or Sears equivalent hooked up there. Use the fine cutoff wheel to grind down the little bit of screw thread that sticks through the liners after you ust endcutters to almost cut them flush. Use the reinfroced cutoff wheel as a small grinding disk to shorten screws etc., smooth around drilled holes.Us the 3M bristles to clean up the residue on an etched Damascus blade and/or bolsters .use small buffing wheels with Zam or Fabuluster to shine parts such as inside of spacer, bolster, liners, etc.
If I err in engraving my Mark on the inside of the spacer, buff/grind it off with Dremel and try again. Often use small Cratex wheels on a dremel tool to cleanout recessed corners, and other small areas. Use the chain saw sharpening grinder stone to clean up or make minor adjustments at the recess where the stop pin fits into the blade tang or liner locking folders.
Oneis good ,then 2 must be better, right!
Stay Safe,
