What is the best edge angle for this knife for general bushcrafting which will include quite a bit of chopping?
Felling axes used by experienced loggers are often sharpened less than half that. My machetes are 12 degrees per side for some uses. It depends in large part in the skill of the user. I wouldn’t go that low with an axe because I don’t use one often, but I’ve been using my machetes for decades in some cases.I assume that by " quite a bit of chopping ", you mean chopping wood, if so, depending on the steel, under 25 degrees per side won't hold up. The last thing you want to be doing is going to a stone while out in the bush all the time.
I'll stand corrected then.Felling axes used by experienced loggers are often sharpened less than half that. My machetes are 12 degrees per side for some uses. It depends in large part in the skill of the user. I wouldn’t go that low with an axe because I don’t use one often, but I’ve been using my machetes for decades in some cases.
I'd be more concerned on securing the handle scales over thinning the edge.
Maybe just sharpened her up as is, then epoxy the scales.
22 is probably okay. Just remember that it's easier to reduce the angle than it is to increase it. That's why I suggested starting at 25 and working your way down.I'll start with 22 degrees per side and adjust from there if necessary depending on its cutting ability and edge retention. Thanks.
