Just a couple of quick things....
By the definition of the compression and tension 'strength', it doesn't matter what size test piece it is. It is psi... "per square inch".
I
think that the impact strength is lower than that of, say, zytel or titanium, because of its nature. So, I'm not surprised by the chunk being knocked out of the butt of your axis, JoHnYKwSt. I dropped my BF Native a couple of times
(DOH!), and while it didn't knock a
"chunk,"it did put a couple of little nicks in the G-10, which were immediately visible because they looked like white spots. Over time, though, the nicks have disappeared (or at least, the discoloration has; the nicks are now as blue as the rest of the scales). I think the
whiteness is caused by microscopic delamination between layers of glass fibers. I'm not sure why the whiteness disappeared on mine, unless moisture and/or skin oils gradually worked in between the fibers. In fact, I think the ones near the blade disappeared first, right after I oiled the pivot area the first time after the drop. You might try putting a little oil on the scales where the discoloration is?...
It's just a ****ing staple!
Maybe we should make knife blades out of staples!
Outlaw_Dogboy, Pax River NAS, Republik of Marilundt
