Maybe
afishhunter
afishhunter
will chime in with some stropping hints and tips.
ok. I'll try. Keep in mind I'm not an expert, and I've never put any polishing compound or past on my strop. (for most of my life my "strop" was my belt or boot toe)
I just pull the edge across the strop using light to moderate pressure, spine raised just enough so the flat of the blade is off the strop away from me, flip the blade and repeat. Never lead with the edge
When you flip the knife, lift it off the strop. 4 or 5 passes is usually enough to maintain the edge.
I use the same technique when using a butcher steel, and never lead with the edge.
(Contrary to popular belief, a steel when used properly removes no to little blade steel. It does, however restore a rolled edge, and will remove a wire edge.)
After stropping, if the edge reflects light, it needs to visit the stone.
I was taught "old school" when knife blades were 1095 or 440A. While other steels may have been used, I never saw them.
Anyway, I was taught by 5 generations how to sharpen a knife. Father and his siblings, grand parents, great grand parents, and a great-great grandmother. All were unanimous: Lay the knife flat on the stone. Lift the spine so the blade flat clears the stone; 8 to 12 degrees per side, 10 degrees being ideal. On the stone, lead with the edge, never follow with the edge. If you lead with the edge, you won't get a
wire edge. After 3 or 4 passes, flip the blade and repeat. Chech the edge with your thumb.
(not by running your thumb lengthwise along the edge. Common sense should tell you that is an excellent way to get a nasty cut. Sadly, I have met a few "people" who's common sense had either left, was defective, or they were born without any, who did run their thumb lengthwise, or licked the edge with their tongue like they saw some idiot actor in a Hollywood BS Western do.)
They also agreed that a wire edge was a bad thing. A very, very, very exceptionally very bad thing to have.
After sharpening on the stone, strop using a slightly steeper angle than you used on the stone, to work off any wire edge/false edge that may be present.
