- Jan 24, 2012
Hello,
I recently purchased a Craftsman 2x42 belt grinder and recently used it to grind the bevel on two paring knives I made. Listed below is the grit progression method I used before heat treatment:
Did most of the material removal with a 120 AO belt.
Hand sanded both knives with 220 then 400 grit sandpaper.
Finished them off with a medium, then a fine scotchbrite belt.
* Ive been using AO belts which I know is not the best way to go, however AO belts in 2x42 are all thats all that's available locally.
I'm looking to purchase some good quality belts and need some advise. When doing your bevel grinds before heat treat:
What specific grits and what grit materials (or brand of belts) do you use?
What grit progression do you use?
Where can I buy the belts you use? Trugrit.com?
Thanks in advance for any input you provide.
