Most factory edges on production knives will be in the ~120-220 grit range, per the belts/grinding tools used to create them. There may be a little extra polish from powered buffing in burr-removal; but, the edge finish will still be relatively coarse. If one is literally wanting to get it as close to 'factory' as possible, that's usually a safe assumption for a starting point.
If you're just looking to restore sharpness to something approximating the factory edge or better, it's usually enough to start somewhere around 320-400, if you're not dead-set on duplicating the factory edge finish itself. More often than not, you won't need to get that coarse to bring sharpness back, and it'll save some steel and some extra work in trying to refine/remove too-coarse scratches as well, especially if the sharpening scratches stray above the shoulders of the bevels, into the primary grind.
