daizee
- Dec 30, 2009
Saturday night we did a batch of stainless wrapped in foil, in a Paragon kiln. The usual stuff. Apparently there was a flaw in one of my packets, and the tip of one blade was visibly burned. We've seen this before with a bad packet, and if it's thin it usually requires... uh, "aggressive" correction.
Steel is S35VN plate-quenched w/ sub-zero, tempered twice at 400F.
So I took this one into my shop figuring I'd be able to grind through the decarb to find good steel, since I'd left the tip a bit thick. But let's test with a file first, right? Unfortunately, my worn file that I use for hardness testing just kept on biting and biting... It skated off the rest of the edge. I kept filing and filing... Finally I took it to the 60grit ceramic over a contact wheel at high speed, and removed almost 3/4" before reaching a spot the file would skate. This roughly corresponded to the burn pattern on the surface. Needless to say, it's a different knife now... (nope, no pix).
So the question is: What's going on metallurgically when this happens??
I figured there would be some thousandths of surface decarb, but it really seemed like the whole tip was soft (though I couldn't easily bend it, in this case). Did it... burn carbon out all the way through? Did it cause some sort of non-martensite structure to form during quench? Did carbides form some weird uneven pattern?
I can speculate all day, so I'm looking for an actual technical answer if there's one to be had.
Thanks!
Thanks!
