What have you found to be the best 2x72 motor size/drive wheel size combo?
What have you all found to be the best 2x72 motor and drive wheel combo? With motors it seems they typically run 1-3hp and I have seen drive wheels from 4"-7". I currently run a 1.5hp and 5" drive wheel but wondering why others have selected their configuration and what advantages or disadvantages that set up gives the maker.
1.5kW 4 pole, 4" drive, for low speed stuff.
2kW 2 pole 4" drive, for mid speed stuff.
>3kW 2 pole 8" drive, for high speed stuff.
All with higher pressure. Low pressure is a different thing.
As Joe's reply shows, the question is not one with a universal answer.It is dependent on the use of the grinder, steels being ground, and setup.
For a "best" general use grinder - 2Hp, 4 pole (1800rpm) 5" drive wheel.
A lot will depend on whether you have a VFD or not. If you can set the maximum speed to whatever you want by programming the VFD (or with trimpots and jumpers on the KBACs), the wheel size does not really matter all that much.
VFD is a must. All my advice is with a VFD. 2 pole on low speed will choke where 4 pole will do fine. When in doubt go 4 pole and small wheel. High speed polishing and diamond belts are out but all else is in. I have 4" and 8" wheels that are changed per use. Mostly 8" that gives 15-40m/s. When doing Ti, small wheel shines as the speed is lower than 5m/s. Wood and laminates also goes fast without burning when on very low speed. One day I'll just have 2 grinders.:)
Since you are currently run a 1.5hp and 5" drive wheel, do you have any problems with that setup? Does it ever bog down at low to mid speeds? I'm making the assumption you have a VFD? If not, Then you NEED a motor and VFD MUCH MUCH more than you need a different motor.
Is that with a 4 pole (1800 rpm) motor or 2 pole (3600 rpm)? If 1800 rpm motor I'm "assuming" you're using a double jumper for 3600 rpm motor? You are with VFD? AND, this is your general purpose grinder, perhaps your only grinder? Lots of folks tout the 4 pole motor with a double jumper get give 3600 rpm while other folks say the 2 pole 3600 rpm motor is just fine.
With a 4" drive wheel 3600 rpm will give you around 3700 SFPM belt speed while a 5" drive will give around 3700 SFPM belt speed. 1800 RPM will only give around 1800 SPFM with a 4" drive and 2300 with a 5" drive wheel.
I personally use a 2 hp 3600 rpm motor with a 5" drive wheel. The motor is over speed to 3850 rpm to give 5,000 SFPM belt speed.
While a 2hp 1800 RPM motor with the double jumper to give 3600 rpm will still give 2 hp at 50% speed and a 2 hp 3600 rpm motor will only give a tad over 1 hp at 50% speed. That's not really a problem for how much pressure do you put at slow speed grinding? At 100% speed the 1800 RPM motor spinning at 3600 rpm is ever so slightly less than 2 hp while the 3600 hp motor is still at rated 2hp.
All in all, it's been my experience in actual use you'll never know the difference between a 2 pole or 4 pole motor while grinding. The 2 pole motor is less expensive and a tad lighter in weight if the grinder has to be moved very often. All in all, I think you'll be happy with either motor.
On the 2hp vs 3 hp - the folks I've read that use the 3 hp motors are the full time makers who are using the 3 hp on the hard grinding at high speed, perhaps 6,000 to 7,000 SFPM belt speed. These folks will have 2 or 3 grinders lined up side by side and never change belts while grinding a blade, move from grinding station to station for each stage of grinding. The only time a belt is changed is when worn out. Once you get up to a 6 or 7" drive wheel to give4 7,000 SFPM a 3 hp motor is desired due to motor bog at heavy pressure. Takes more power to turn the larger drive wheel.
When I first started grinding I thought 4,000 SFPM was plenty fast. As I gained more experience I now find 5,000 SFPM to be a good grinding speed. I doubt I'll ever get to 6,000 SFPM comfort level, I'm just a hobby maker. AND - the idea of a 36 grit belt breaking at 6 or 7,000 SFPM is scary!
Remember, a VFD is a MUST. My first grinder was a belt driven with 3 step pulleys and I didn't see the need for VFD - cost too much money since I had 2hp 1ph motors laying around. When I built my 2nd grinder I got the motor and VFD - WOW - what a difference. A decent variable speed setup will do more for your grinding than you can imagine - until you spend a week or so with variable speed.
