Dave: Nope, don't wear it while I sleep, but I wear it when I'm in the garage, even hours after I'm grinding with the double garage door open
. People give me funny stares when they are walking across the street and see me in the garage with a shower of sparks wearing a gas mask. Probably will get funnier stares now that my work coat is a woodland camouflage jacket (washes easier than my old one).
Cray: I'm no expert, so take what I say at your own risk. You should probably call 3M or North or whichever company is going to make your respirator. If you get your lungs hurt, don't sue me.
If you're up against a hazardous concentration of formaldehyde, acid fumes, and oil mist, you should probably invest in a set of Organic Vapor/Acid (OV/Acid) cartridges and prefilters in P95 or P100 (P100 is better, but I haven't found it necessary).
I would suggest a 3M 6200 (which is medium, if you are small, get a 6100, and large is 6300) half mask respirator. I've worn a North 7700 before at someone else's place, and I think its slightly more comfortable, but it's probably harder to get cartridges for.
http://www.envirosafetyproducts.com/html/Subcategories/6000series.htm
This website shows you what a 3M 6000 series half mask looks like, and also shows you the cartridges. Cartridge #6001 (organic vapor) is what I use, and it works OK for me, but I don't go up against acid, and I rarely grind Micarta (formaldehyde/phenol fumes). For about $0.65 more, you can get a #6003 (organic vapor/acid gas), which
probably will work for you. Not sure though, you should probably call a respirator company like 3M and find out.
That's the gas and fumes part, you will need protection against mist and particles too. Earlier I wrote that you should get a
P95 or
P100 (I think they make a P98 or 99 too, that should work too). I use a 95%, which is the lower efficiency and protection of the bunch, but I have yet to smell any funky particles or get steel boogers. I do not think that the grinder puts out particles so small that that the 95% filter could not stop it before it became of a harmful concentration. I use a N95, but I don't go up against oil based particles and mists. The difference between the N and P filters is that P handles oil based hazards. On that website, they sell P95 filters as well, you should get those if you decide to go with the prefilters. You'll need a pair of 501 retainers too. I suggest getting two pairs, because I have had one get damaged.
To assemble, put the gas/fume cartridge on, then put the particulate prefilter over it, and then snap the retainer over it to lock it in place. This system works good for me. Hope this info helps you.
Stay safe! (That means respirator, glasses, goggles, face shield, ear plugs, coat, chemical resistant apron, and boots)
