What is a good use for 1/8 " Brass
blgoode
I have access to some 1/8" Brass......looking for ideas to use it on.
ANYTHING .............Buler...Buler?
B.,guards, buttcaps,spacers. You can laminate other metal, such as 99.99 silver to it for nice results, too.
Sharpen em each end and play mumblety peg.
Sharpen one end like a small chisel stick a handle on it and make an epoxy clean up tool. (The brass won't sratch the steel)
PINS
Buy some tubeing make Mosaic Pins.
Gap rod
Make little culry hooks
Cut two inch pieces and make a punk Mr. Potato head.
stacked handles....just be careful while grinding because it can heat up and delaminate.
Is it round pin stock, flat bar stock or sheet? All sorts of uses come to mind. Do you have access to enough that you're willing to share at a fair price?
John
its 1/8 flat. It is irregular shaped pieces. The guy at work hase a little. Its not an awfull lot but its very tempting. What size do you need?
I'll try to cut some in the morning. CAn't promise they will be square :)
as requested...I sent you a small package of 3 pounds. Let me know when you get it.....email me about the payment we discussed....
LEt me know what you do with it John
did you mail a check?
I'll let you know when I get it if you did.
got it :p
Let us know what you do with it.....
