Use only the slightest amount, let it dry, then install.
That is very similar to how I have used Loctite. I guess I have Loctited 7-8 Kershaws after opening them up for maintenance. Though if there is old LT on the screws, alcohol isn't enough and I have to use nail polish remover. (Try explaining THAT to the clerk at the grocery store. "It's for my knife!")More info; when applying, only use a drop on the threads of the pivot bolt - and it helps to completely remove it and wipe the threads with alcohol to remove any BlueLube before applying. Once the bolt's been replaced, there's plenty of time to find the sweet spot where the adjustment feels right, and then let the knife sit over night. I don't use 'LT' very much, but when I do it works well.
Anyway, I was hoping to get a better interpretation from Benchmade, themselves.
I work Mon-Fri so it will be awhile before I can call them. I guess I could email them, though.
I went ahead and loctited the screw. Forgot to clean it first, duh. But looked completely clean, no sign of previous loctite.
