What is finer??
2000 grit sand paper, or 0000 steel wool?
The reason I am asking is I am finishing a knife handle in Oak diamond wood. When I have finished woodwork projects in the past I have used steel wool to rub in paste wax. I have hand sanded my scales to 2000 and am happy with the finish, but don't want to knock it down any if steel wool is not as fine.
Thanks
Brian
They're apples and oranges I'm afraid, but I believe in this application the 2000 grit sand paper is finer.
I've been experimenting with pink scratchless buffing compound and a low speed buff for this application with good results (if shiny is what you're after).
Nathan is correct, they are different. FWIW, some woodworking charts list 0000 as being 600 mesh equivalent. Others list it higher.
The difference is best compared to a scraper and an rasp. Steel wool shaves the surface with a wide loop of fine metal, and sandpaper scratches the surface with a pointed Crystal of hard material. For rubbing in the final finished, 0000 is perfect, and for sanding down to a glassy surface, 2000 sandpaper is perfect. Together they will produce a perfect finish.
Using steel wool and paste wax together defeats the purpose of the wax. Would you wax your car that way?
Diamondwood is a laminate. It can be polished to a mirror shine on a buffer, or by hand. Sand to 800 grit (or use 0000 steel wool), then buff shoe-shine style with a soft cloth and Simichrome, Flitz, etc. Wax is not necessary, but it won't hurt anything.
