what is proper batoning technique for a fixed or folder?
Splitting wood...getting to the dry middle in wet weather...
What is the proper batoning technique...
...for a good quality locking folder
...for a fixed blade
Thanks
There is usually more to selection of where to baton in the wood than how to actually baton which is as simple as hit the knife with a stick and drive it through the wood. You go by the same basic principles of dealing with knots as you do when splitting wood in general.
With folding knives you can release the lock and baton them through softer woods. As the wood gets harder to split you will need to engage the lock to allow the blade to actually be driven through. The impacts are however very severe at this point.
Unless the folder is really robust this stands a great chance of breaking the lock. What you can do is just split the wood enough to drive in a wedge and use that to finish. The wedge can just be another piece of wood or even a rock.
There is an arguement proposed by some, that the knife should never go off horizontal when batoning as this raises the stress on the knife (it doesn't), and that you should never press down with the off hand as this also makes it much harder on the knife (it does and a *lot*).
However simply because it makes it harder doesn't mean the knife should be unable to do it. A tempered steel blade should not fracture from impacts with a stick when in a piece of wood and there are lots of makers that won't impose such limitations on their knives.
-Cliff
"Unless the folder is really robust this stands a great chance of breaking the lock. What you can do is just split the wood enough to drive in a wedge and use that to finish. The wedge can just be another piece of wood or even a rock."
True on that, I had a crkt m16 and i did that with the knife locked and it broke. the washeres split, and the lock wouldnt engage anymore. this was after about half hour of beating on it. it was pretty tough though.
If I only had a folder I would spend time carving wedges and only use the knife to make the initial 1cm deep split.
I have seen a huge log and I mean about 2' in diameter split with a little hatchet. The guy made a load of wedges to chase the split, it was pretty impressive. I will have a look around and see if I can find the picture.
Ol' Jimbo did that IIRC and it is on the OutdoorMagazine forum...again IIRC.
Cool stuff.
Here's a shot of my favorite Scout doing the same sort of thing.
He was determined to split these rounds, so we made a wedge and a pin...note the baton :D
The first shot is on impact and the second is the aftermath.
Thats it, good find! :thumbup:
Ebbtide, there is nothing cooler that seeing satisfaction on their face is there? Its better than doing the job yourself :D
