- Jan 3, 2012
Is it when the blade moves with little force, or if it moves under any stress hand-caused is that still play?
Price is $300 ea (shipped within CONUS). If you live outside the US, I will contact you after your order for extra shipping charges.
you could try playing with the pivot on the 710
I'm talking with a benchmade 710 in m390. It doesn't feel to really move unless I exert a little force, but a $10 winchester doesn't' seem to move with the same amount of force. May just be the nature of the lock though.
first of all, are you talking about vertical or horizontal blade play? By that I mean does the blade wiggle side to side or up and down? In my opinion ANY vertical play (up and down) is absolutely unacceptable with an axis lock. Some back locks will have some normal vertical play and framelocks can have a bit in the form of lock bar flex and may develop vertical play with hard use (abuse). Horizontal play on the other hand, is very much subjective. As mentioned above, almost any folder can be muscled into wiggling a little bit. On an axis lock knife, you should be able to snug down the pivot a bit and tighten out the play at the possible cost of speed of deployment. If you can tighten the pivot so that the blade will not open and close freely and you still have horizontal play you either have ridiculously high standards or something is wrong with the knife and you should contact benchmade.
Blade play is blade play. I have two knives that will not allow any play, no matter how much muscle I use or how fast I wiggle the blade. These are the exceptions though since pretty much every other knife I have will wiggle a little bit if forced.
I don't really find blade play unacceptable unless you can hold the knife by the handle and shake the blade about like a rattle. I don't really like it when I can muscle it into wiggling, but it's not a big deal.
are they fixed blades?![]()
