What is the better Horn?
Other than personal preferences which horn material is more durable for a knife handle and would stand up better to normal hunting use? Sambar stag or water buffalo horn?
I have one of each, in the Buck 110 and the Asian Buffalo horn seems like it's vary dense and hard, compared to the stag.
Since horn stays on the animal all its life, and stag drops off every year, horn should logically be denser and tougher.
It really should not make much difference. They both can be brittle. Much of it depends on the condition of the materials to begin with.
Water buffalo horn is not much different than deer horn. They are both a hairlike growth of the animal..........and neither is very dense.
Sambar is, however, less prone to warping than buffalo.
If I am not mistaken, antlers are a calcium growth like bone and are not a fibrous hairlike growth like horn. I don't know about buffalo, but sheep horn seems to be quite a bit tougher than stag.
Tom, has a good point. This is true.
Horn that has been pressed, or formed has a high potential of becoming warped. Horn tip though, is a much better material, and not nearly as prone to warping like pressed, or formed horn. as far as horn tip, or pressed/formed, it would depend on the handle size if you can get a large enough piece of horn tip to suit your needs (horn tip is much preferable than pressed/formed).
Either would be fine for normal hunting use. (unless your going to be chopping and throwing your knife around, either is fine)
Thanks for the feedback..
I don't throw knives and generally don't chop much or at all... I have a small hatched or Wyoming Saw..
I do believe Keith M. has nailed it in regard to what each is comprised of.
