I know the specifications for the knife I want but not what knife has these. I have spent hours searching and cannot figure out what knife has what I want. Please help!
This is for a filed knife that will be mostly a backpacking/bushcrafting/survival/hunting knife in that order.
Blade material not rust prone (no coating on blade wanted or needed, no 1095 etc. but actual stainless not necessary)
High saber grind (want at least tiny flats to easily lock onto the jaws of my Wicked Edge so no full height grinds)
No thumb ramp and spine parallel to blade edge for at least a short distance (to easily align on the Wicked Edge)
Full tang
G10 handle
Blade length over 4" the closer to 5" the better
Weight under 6.5oz the lower the better
Blade thickness over .10" under .20"
Blade edge to spine distance long enough to allow me to not have to use the tip if cutting on a flat surface
Blade shape is otherwise open, I like drop points but not married to anything
Current have a Fallkniven F1 VG10 (blade too short, blade is a little chippy, does not get scary sharp, full convex too hard to hold in sharpener and had to re-profile for secondary bevel for Wicked Edge, great weight) and Bravo 1 rampless S35VN w/ G10 handles (too heavy, too thick of blade, otherwise great) so hope that gives an idea of what I like as far as style and aesthetics.
I just cant seem to find what I want... everything is either too thick and heavy, too short, wrong blade material or something else not what I want... please help me find my field knife! Closest I have found is a Bravo 1 LT, but still a lil heavy. I count grams backpacking.
Full tang
G10 handle
