Some of you may burst out laughing when looking at the thread title. Well, I'd been badly cut once by a slipjoint when I was young (the blade suddenly shut on me while I was scraping something) and I had been avoiding slipjoints ever since. But lately I've come across some of pictures shared by fellow forum members of their slipjoints and I think they're wonderful. I'm tempted to start collecting (and using) slipjoints again; but, pardon my ignorance, is there a proper way of handling slipjoints so that you can avoid yourself being accidentally cut? Thanks!
Welcome to the forum, bchan.
I'm not going to laugh, but this brings to mind that there is a whole couple generations that is young enough that they may not have the experince with slip joints that us older farts do. When Buck came out with the 110 in 1963 it changed knifedom. Locks became popular, and today there are not many traditional pocket knives sold in relation to the vast amount of tactical, hunting, and Chinese and Pakastani knock offs of them that are sold. Most young guys who did not have a old grandad to teach them don't have familiarness with slippys.
A slip joint is easy to use, you just have to get used to certain aspects of it. Once you open it, it will be held open by the pressure of the back spring against the blade tang. If the number of pounds of force pushing on the back of the blade exeeds the number of pounds of force being put on the blade tang by the spring, the blade will close. This can be good or bad. In the old days we would just brush the back of the blade agaist our leg to close it and drop back in the pocket. Its a simple mechanisim that stands up well to alot of years of use without a lock to wear and possably fail. Also it works well under diirty conditions, again because there is no lock that may need tight tollerances to work well. As long as its treated like a cutting tool, you'll do fine. Like one poster said, don't stab anything with it, and don't puch on the back of an open blade. A slip joint takes a tad more care to use, but then with any sharp tool you should be carefull. In the long run I think a slip joint is a better knife than a lockblade. I've seen a bad result of a young guy having too much faith in his Buck 110's lock, and having to be taken to the ER. He got careless, treating his knife like it was a sheath knife, certain it would not fold on him because it had a lock. He ended up with his right index finger short at the last joint. The only knife that will never ever fold up on you is a sheath knife, or fixed blade as they are called now. With a slip joint, you know it will fold, so you are more carefull in using it.
Work with one for a while, and take it slow and carefull. Once you get used to it you'll be fine. Just don't push hard on the tip, and press into the cut or slice in the direction your cutting. The dynamics of what your doing will keep it open. I wish I were close to you so I could come over and give you some hands on instruction. It's just different. Think of it this way, if a slip joint were a handgun, it would be like a single action Colt peacemaker vs a modern tactical that would be like a Glock. They just require a different touch. A slip joint is kind of like stepping back in time to what our grandfathers carried and used. I love retro stuff.
