I purchased an old Norton tri hone set. IM303
The guy said he used WD40 as his honing oil.
I am thinking possibly going to water.
How should I clean these up? They show no noticeable wear.
Clean up usually involves allowing some light oil to sit on the surface for a few minutes, agitate with a fingertip, and wipe off with a rag. Boiling the oil out of them would be the next step if you wanted to convert to water, but is not a good idea in my opinion - they work a lot better used with a light oil such as mineral oil or WD40.
You can use them with soapy water without boiling first and this will give you an idea of how it works without permanently removing the factory oil job.
Martin
NRA, I've not heard of a 303 Tri-Hone system. I have heard of a 313 Norton Tri-Hone system which is excellent. I have that system. If the previous owner said he used WD-40 that is what I'd use. It is mostly a lighter mineral oil and cleans up easily. Just spray some on and use a bristle brush or wire brush, to work and loosen any swarf then wipe the stone off with a cloth rag. They should be good to go. Using oil will give you better feed back and a finer edge. If your stones are in good shape and level that system is worth over a hundred. DM
