What is this weird-ness in my steel
So today I was working on a D2 puukko for a budy who is going to be doing some wild game testing with it. The blade is D2 that is from a planer blade that I annealed. I have a lot of these blades do I have been looking for a use and it's perfect size for puukko blades. So any way I was grinding away on it and when I switched from the blaze belt to the 300 gator belt this weird spot showed up. I kept grinding and it never went away. I dont know how deep it goes but it's not on the other side and I'm at my desired edge thickness of .02 so I don't want to remove any more befor heat treat. Looks like aloy banding but that's usaly spread out in waves not a patch of what looks to be a softer section. Thanks guys, I'm not real concerned as this is just a test blade and cosmetics are not top priority at this time.
Here is the little funky spot
As you can see it's not on the other side.
But like I said befor this is a mule of sorts to just test heat treat and cryo treatment on an oven annealed D2 planer blade.
I believe that is steel impurity. Sometimes happened to me too. Only way is grind it away...or ignore it. ;)
Worm hole, prevalent in the north west. You slso need more radius between tang and blade.
Hoss
^ yeah, good call on that radius I think
That looks like it goes in, not out, meaning it probably isn't a big plate carbide. My guess would be a large soft inclusion, which doesn't bode well for the quality of the melt.
I've used a lot of D2 and I've never seen that before. It's known for some weirdness, but not like that. This is pretty typical :
You can see the carbide banding there. That's pretty typical and not a bad thing.
Is it possible you have a spot of soft decarb? Didn't you do some in the forge annealing? I don't know, but perhaps there was a spot that didn't play nice due to a hole in some foil, etc?
Yeah I completely spaced out the radius. Got it set up for filing and grabbed a sharp shoulder file and went at it. I do blan on fixing it.
I did aneal this D2 but I did not do it in foil. I stacked 9 blades (each blade is 26" long) in the oven and ran the program, took somthing like 16hrs if I remember correctly. I'm hoping it's just a weird anomaly that I never see again. But I does seams softer becaus it's created a low spot in that area.
